Lost connection Arlo Pro 4 camera when it is raining
Hi,
I have a very strange problem with one of my arlo cameras. I have Arlo Pro 2 base station with two Arlo Pro 2 cameras. I have bought an extra Arlo Pro 4 camera (VMC4050P) that is connected to the Arlo Pro 2 base station. The connection to all three cameras are normally very good. Though when it starts to rain I lose connection to the Arlo Pro 4 camera. Light rain is enough to break the connection. The other Arlo Pro 2 cameras stays connected. What is going on here?
@Broadwin wrote:
Hi,
That is strange. If you swap the Pro 4 with one of the Pro 2 cameras, do the symptoms change?
Might also be worth looking inside the Pro 4, and making sure no water is getting in.
Try swapping cameras around to see if it's the camera or location. I wonder if the Pro 4 is at the edge of useful signal and the rain is deflecting/absorbing enough signal to cause the issue.
Arlo Pro 4
labels
Samsung SmartThings
