Landscape lighting 12vAC to 5v step down
Does anyone know of some type of step down converter to run the power cable for a Arlo Pro 4 off of a low voltage landscape lighting system? I'm guessing you'd need some type of 12vAC to 5v USB? Has anyone done anything like this?
Never heard of anyone doing this but a car USB charger may work. The biggest issue would be whether the lighting power supply can supply sufficient current.
Arlo Pro 4
labels
Samsung SmartThings
