I have various versions of Arlo cameras up to Pro 4 that are recording few second videos when they a
I have various versions of Arlo cameras up to Pro 4 that are recording few sec videos but are set for 2 minutes. What is wrong?
5 REPLIES 5
You can try rebooting the base station to see if that helps but a frequent cause of short recordings is a connection issue. Try moving the base as far away from the router as practical.
The Arlo Pro 4 has no base.
What about the others???
I see the same thing with my Pro 4 cameras, although I have my setting to record as needed not for a fixed period. It still cuts off the video for no good reason. I suspect it is a server side issue or the camera is causing it. my ISP uplink and wifi is solid (I monitor it fastidiously).
@Train64 are you still seeing this same behavior?
Arlo Pro 4
labels
Samsung SmartThings
