How to delete videos in bulk from the feed? The new security software doesn't offer "select all"
It used to be possible to delete a lot of videos at one time. If workment were on the property and I recieved 40 alerts it was easy to delete them. Now I've added the Home Security System, and aside from some other annoying things I can't delete groups of videos. I have to open each one, select the menu, select Delete, then answer Are you sure you really want to delete the event. This is a downgrade of the usability of the system imho.
WHile it's not everyone's cup of tea, I suggest NOT deleting them. Just let them roll off at the end of 30 days. That way you can retrieve them at a future date within the plan's 30 days as a "just-in-caser". You can't retrieve deleted videos unless you have local storage in use and can find them there.
YMMV.
given that I have no other choice, that's what I'll be doing.
Arlo Pro 4
labels
Samsung SmartThings
