How do I get notified. on my phone when it is activated
  • 1 Reply
  • 914 Views
wattsd
how do i get notified. on my phone when it is activated
Check your active modes and rules. Push and/or email notifications are enabled there. Also, the app needs to be running in the background for push notifications so make sure you're not force closing or logging out of the app. You may also want to check the phone settings for the Arlo app to ensure that notifications are appropriately enabled/set.
  • 1 Reply
  • 915 Views
