Hi. Is there an Hi. Is there an adaptor to upgrade my pro4 so that I can use my full fiber as I'm
  • 1 Reply
  • 218 Views
Trev2727
Hi. Is there an adaptor to upgrade my pro4 so that I can use my full fiber as I'm informed sky's max 6 doesn't split from 5 to 2.4ghz
Many dual band (or tri-band) routers don't let you give different network names to different bands.
My own router (currently an Orbi 873) doesn't, but I've found that just ignoring the "advice" to connect my phone to 2.4 ghz works with that router.
If that doesn't work with Sky, then you'll need to get a VMB4540 or VMB5000 smarthub (which connects to your network using ethernet), and then pair the camera with the smarthub.
  • 1 Reply
  • 219 Views
