Not receiving notifications to my iPhone from my Arlo pro 4 camera
What mode is the camera set to?
Do you have motion triggered recordings in the library?
Does the motion test utility work in the camera settings?
My mode is on home. No where on my app is the word library. Is it because I don’t have a paid subscription?
With the pro4 cameras you require a subscription to be able to record to the arlo cloud library.
The app has recently split into two versions, the original version has the cloud recordings located in the library page, the new version has them located in the feed page.
The mode should be set to the armed or away mode for the cameras to be actively monitoring for motion.
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
Arlo Pro 4
labels
Samsung SmartThings
