Help connecting Pro 4 to router WIFI
  • 5 Replies
  • 2250 Views
jerry6004
We just switched from AT&T to Spectrum for internet.  When this happen our camera did and will not connect to the spectrum router.  Yesterday I purchase a NetGear AC 1900 and it still will not connect.
I can see the camera on the NetGear app connected to the 2.4 guest network but it still is not functional.
Does Arlo recommend a specific router?
5 REPLIES 5
If you have the guest network set for network isolation, then you need to change that setting.  Also, you will need to connect your phone to the guest network for onboarding.
jerry6004
Sorry but I do not understand what network isolation is,  and I do not see that option on the Netgear app?
What Netgear Router model do you own?
jerry6004
AC 1900/ R7000
@jerry6004 wrote:
AC 1900/ R7000
Thanks.  Look over pages 78-80 here: https://www.downloads.netgear.com/files/GDC/R7000/R7000_UM.pdf
Make sure Allow guests to see each other and access my local network is checked.
Also, make sure the wifi security is set to WPA2-PSK [AES].
  • 5 Replies
  • 2251 Views
