Geofencing and Scheduling
It looks like they may have added an "Enable/Disable" feature in automation recently?
Has anyone had success with the following?
Schedule:
Morning disarm cameras at 7am
Evening arm cameras at 7pm
Geofencing:
Arm cameras when everyone leaves
Revert to schedule when anyone is home
That's been there all along.
Schedule:
Geofencing:
"Revert to Schedule" isn't possible, the new design (unfortunately) requires you to change to a specific mode. You can then set up the system to follow the schedule at the next trigger time (7 am and 7 pm in your case).
It's been a while since I enabled geofencing - I turned it back on a few days ago, but haven't been out enough to assess reliability.
Can you give some details with what is/isn't working with your setup?
Arlo Pro 4
labels
Samsung SmartThings
