Forgot Wi-Fi password
While using my iPhone, I see a Arlo network available to connect to. It is labeled ARLO_VMB (with a series of numbers). It is a secured Network. I click on this to log on this Network but do not remember my password. How do I recover or change this password?
Since this network is from the Arlo base or hub, you can't log in. That's on purpose since being able to do so could quite well open up security issues. Arlo is a closed system and only the cameras can connect to the base/hub usin g the proper procedure.
Arlo Pro 4
labels
Samsung SmartThings
