Constant delays and obstruction to return the product
I've been buying products online for more than 15 years and Arlo is nothing but a bunch of thieves. Constant delays and obstruction to return the product. They stole $800 from me. Well done. I am contacting my lawyers.
Are you able to provide more details about the issue you're experiencing?
If you're trying to process a return or check on the status of an order, please refer to online store support here: https://www.arlo.com/en-us/contact-us.html
Arlo Pro 4
labels
Samsung SmartThings
