Can't Find Sensitivity Setting in Arlo Secure App
  • 1 Reply
  • 768 Views
guitarjim
From what I am reading, there should be a sensitivity setting in Settings, but I don't seem to have it.  I do in the sensitivity test, but there is no way that I can see to set the camera.  Any ideas?  Camera is an Arlo Pro 4.  App version is 4.13.
Do you see "Library" in your app?  Or do you see "Feed" and "Dashboard" instead?
If you see "Feed", then
  • go to the devices screen
  • select the camera
  • press on the settings wheel in the upper right
  • open the "Default Mode Settings".
If you see "Library" instead, then go to the Modes page, and edit the mode you are using.  The sensitivity is in the camera rules.
  • select the camera
  • 1 Reply
  • 769 Views
