Can I use Pro 4 with wifi 7? model VMC4041P
I upgraded to wifi 7 and now my Arlo Pro 4's will not work. Any workaround for this? (model VMC4041P)
Best answers
Make sure the router is still set to allow WPA2 (AES) security. WPA2+WPA3 is ok.
Are you using the same network name/password you were using before the upgrade?
Arlo Pro 4
labels
Samsung SmartThings
