  • 1 Reply
  • 1023 Views
BrianPerr
Hi. Question on charging the Pro 4. If the camera is mounted outside near a window, would it be possible to connect the 8 foot charging cable from inside the house by opening the window, ie, is the back accessible so that I could I charge it without ever having to remove it?
The magnetic charging connection is on the bottom of the Pro 4 (not the back).  It is accessible if you use a normal Arlo mount (and likely is accessible with most third-party mounts).
So you can charge it in place if weather permits.
  • 1 Reply
  • 1024 Views
