Camera doesn’t work
  • 1868 Views
Lisabaker99
I have several Pro 4 cameras but one stopped working. I charged the battery and even exchanged the battery with others so it’s not the battery. The blue light does not come on, I cannot link. The camera seems to get no power or just doesn’t work. Is there a reset? It’s only 2 years old.
@Lisabaker99 wrote:
 Is there a reset?
There is a sync button inside (remove the camera from the housing).  If you hold that down, the LED should flash amber after about 15 seconds.  If that happens, you've done a hardware reset.
If this works, you will need to remove the camera from the account, and then re-add it.
Dr_Rischbieth
And if it doesn't (my case), what then ?
PS What a useless forum !!!
Then (assuming the camera is charged) the camera has failed.  If it is still under warranty, then you can contact support for an replacement.
Why are you trolling @Lisabaker99's thread???
  • 1868 Views
