Bought Arlo Pro 4 from best buy. Get it home and no base station. Is the Base Station an option?
@Twolfe wrote:
Base Station not included?
The camera can connect directly to your home wifi.
You can still get a smarthub if you like. I'd suggest either the VMB4540 or the VMB5000 if you want to do that.
Note some Arlo bundles do include cameras + smarthubs.
Arlo Pro 4
labels
Samsung SmartThings
