Arlo pro 4 wireless - front yard camera drains battery in just 1 day
I currently have 3 arlo pro 4 cameras set up on my house, 1 in front, 1 in back, and 1 at my garage. My front yard camera drains a newly charged battery in just 1 day! I replaced it yesterday morning it was at 100% I even turn the camera off during the day then back on before bed, checked this morning my battery is at 16%! I even have a solar panel connected to this camera and seems to drain even fast with that. Both of my other cameras hold charge no problem and are further away from the router than this one. I've disconnected, reset, swapped battery, everything I can think of and the problem stays the same or gets worse. Im really wishing I wouldve just saved some money and bought a different system. Help.
First, swap cameras around to see if it's the camera or location that's causing the problem. You may also want to remove the solar panel for testing since it seems to be possible for a faulty panel to drain the battery.
The zone stilll needs a recording for the servers to decide if it's within the zone or not. The only way around this is to use AC power for the camera so the zones are locally processed.
Arlo Pro 4
labels
Samsung SmartThings
