Arlo pro 4 draining in two days after firmware update
My arlo pro 4 cameras are 3 months old, not that the battery life was that great to start with I'd get a couple of weeks before they needed charging but now one of the cameras is draining completely in 2-3 days.
Last week I bought the camera in to charge and it requested a firmware update. I allowed the camera to complete the update but since then it has completely drained twice. I had it set to 'best battery' and the camera is recording about twice an hour during the day
I need to charge the second camera in the next couple of days, worried this will happen also. Please advise wha.
Is this with activity zones? You might try removing any zones as a test, and see if you get a flood of recordings.
Also, I suggest rebooting the camera (removing the battery and reinserting it). If that doesn't help, try a full reset.
this just started happening on one of my Pro 4's as well. not a battery issue as I've tried with 3 different Arlo branded ones; all these have drained to zero in around 30 hours.
nothing else was changed and it behaved well before a recent update.
I've tried re-pairing to both Wi-Fi and a base station and the same drain occurs.
I'll try doing the full 15 second reset and see what happens.
Arlo Pro 4
Samsung SmartThings
