Arlo pro 4, can I use them at the same location but on two different networks?
  • 1 Reply
  • 741 Views
eleer329
Can I use the Arlo pro 4 at the same location but I’m on two different networks?
Not sure what you mean by "on two different networks".
You can set up the Pro 4 to connect with a specific 2.4 ghz WiFi network - you provide the network name and passphrase, - or you can set it up to connect to a compatible Arlo Base station that in turn connects to your router usign ethernet.
  • 1 Reply
  • 742 Views
