Arlo pro 4 camera
Camera wont record. I have a new usb memeory stick in the base
Did you go into the hub's settings and activate Local Storage, including formatting the drive? The drive must be formatted as FAT32 and using the app to format it in the hub is the easiest way to do that. One caveat is that the drive must be at least 16GB.
Arlo Pro 4
labels
Samsung SmartThings
