Arlo pro 4- battery life
If you read the FAQs here on best camera positioning and motion sensitivity settings you can probably eliminate the issue quickly.
First, the sun's IR be reflected off moving branches/leaves will always be an issue for any device that uses IR detection. The best solution is to eliminate those items from the camera view. You want to point the camera to where you need the detection such as the sidewalk up to the door, not at the sky, street and trees. You may well have to move the camera to accomplish this.
In addition, many of use use custom modes with rules that have lower sensitivity during the day to minimize any such reflections and false triggers. You can then use the schedule to automate switching as needed.
Finally, remember that the sun's position changes over the seasons.
Arlo Pro 4
labels
Samsung SmartThings
