Arlo pro 4 batteries need changed every 24-36 hrs. Temps are 30-60 deg F. Is this normal?
The batteries need changed every 24-36 hrs. Temps are 30-60 deg F. Is this normal? I can’t believe so. Also I only schedule the cameras on during night time hrs.
Definitely unusual.
- Are you seeing any evidence of connection issues (failure to livestream, camera showing offline status, ...)?
- How much video is being recorded per day (roughly in minutes)?
- Are you using activity zones?
1. No all
2. 5-9 minutes at the very most
3. No
@Dks33 wrote:
1. No all
3. No
This isn't normal, and you might have a defective camera or battery.
You could try contacting support (assuming you are still under warranty or have a subscription). If it's a new purchase, I'd exchange it with the seller first.
I'd also suggest bringing a camera closer to your router or hub, depending on how the system is connected. That will tell you if the issue is the camera/battery or something about the location or wireless environment is the problem. Also, what is the construction of your house? Non-wood structures can be a real problem.
Arlo Pro 4
labels
Samsung SmartThings
