Arlo pro 4 back screw fallen out
Hi, the small circular bit that is in the back of the camera to screw on the wall mount, it’s fallen out: it’s 15 months from new. Any advice?
If you still have it or can find it, you can epoxy (or use some other strong glue, NOT Super Glue) it back into place. It may be that you're tightening it too much so be careful snugging it down - it's just a press-fit.
Arlo Pro 4
labels
Samsung SmartThings
