Arlo Pro4 camers with spotlight - internet requirements
What is the minimum internet required to run the Pro 4 spotlight cameras, and how should I measure it? I am in an isolated location and need to have coverage while away from the location.
2 mbps upload speed per camera. You can measure this using speedtest.net (or the free ookla speedtest app on a smartphone). Note you need the upload speed, not the download speed.
The cameras need the internet connection both when you are home and when you are away.
Arlo Pro 4
labels
Samsung SmartThings
