Arlo Pro4 Connection to 2.4GHz
  • 1 Reply
  • 1295 Views
BCook72
I'm having difficulty connecting my cameras to my WiFi.  I even went and bought a new router to ensure I could turn off the 5GHz signal and use only the 2.4GHz signal.  My camera will chime when reading the QR code, but then it won't "discover" any of my 3 cameras.  I've quadruple checked the WiFi SSID and passcode.
Is there any punctuation in the SSID?  If there is, try removing it.
Also, if you are only trying the app, then I suggest also trying a PC (browse to my.arlo.com).
  • 1 Reply
  • 1296 Views
