Arlo Pro 4s live audio not loud
I just bought a Arlo Pro 4 and the setup and everything else was ok but when I go into the Arlo app on my iphone, the live audio isn't loud enough to hear and in order to hear through it you have to put your phone to your ear almost like you are talking with someone on the phone but with out speaker on. Is there an option to make the volume higher or even a fix to this because the volume on my phone is at max and it's still pretty low.
jezreel101,
You could try plugging in headphones. Is the audio louder when headphones are plugged in?
@Chadtb85 wrote:
So what will that determine if the vol is fine with headphones?
It determines if the issue is in the phone playback or in the microphone sensitivity of the camera. If headphones work fine, then the microphone sensitivity isn't the problem.
Either way, the problem remains. It would be good if there was an option in the app to boost the level.
Arlo Pro 4
labels
Samsung SmartThings
