- Email to a Friend
I reviewed the Arlo Pro 4 and Arlo Ultra and I having this questions:
1. What is the principal differences betwen Arlo Pro 4 and Arlo Ultra
2. Arlo Pro 4 and Arlo Ultra, it is possible that your operation to be with direct conect to electric power all the time and not use battery¿?
3. The use of Cloud for recording video, it is free pay for Arlo Pro4 and Arlo Ultra¿? Please comments if the recording in Cloud of image having some price.
Thanks for the answer
Regards
FJZA
- Email to a Friend
Cloud recording is not free, it requires a paid subscription. https://kb.arlo.com/88/What-are-the-available-Arlo-subscription-plans-and-how-much-cloud-recording-i....
You can power them using the AC adapter all the time (and they will function when powered even if the battery is removed).
The Pro-4 is 2K (2560x1440), the Ultra is 4K (3840x2160). The Pro-4 has a slightly smaller field of view (160 degrees, compared to 180 degrees for the Ultra). The Ultra also has wind noise reduction on the microphone.
The Pro-4 can connect either to a smarthub base or to your wifi. The Ultra can only connect to a smarthub.
- Email to a Friend
Arlo Pro 4
