Arlo Pro 4 streaming issues
I'm having some issues with my Pro 4 cameras I bought. I connected them to our network but I'm having issues with live streaming. It's showing that the camera has strong signal so I don't think it's the connection to our wifi. I'm still getting alerts and I can download the videos it records when there is motion detected which is great but I want to be able to live stream if needed. Would buying a Smart Hub and connecting to that fix the issue? I have a system of Pro 3 cameras set up at another location with a Smart Hub and there never seemed to be an issue. I just don't want to buy a Smart Hub and it doesn't fix my issue.
The hub shouldn't make a difference. What happens if you bring a camera closer to the router for testing? What is your house construction?
Arlo Pro 4
labels
Samsung SmartThings
