  • 5 Replies
  • 1265 Views
Asumasu
I read the threads related to the same problem but they were not helpful.
I have 3 identical cameras on wifi, no base station. Firmware = 1.080.17.3_50_94fae6e. One of them stopped recording. It detects motion, as per the yellow light coming on when I wave in front of it. I restarted it, removed and reinserted the battery, no help there. If there is an explicit start/stop recording button somewhere, I haven't found it. No, I haven't done anything to this camera that I haven't also done to the other 2. Actually I haven't done anything to any of the 3 since I first installed them about a year ago. Connections to wifi are "strong". iPhone OS, in case it matters.
Please advise.
Thanks.
5 REPLIES 5
Dannybear
Have you checked the camera rules in settings?
Can you make a manual recording while livestreaming?  Note if you 2K livestreaming enabled, you'll need to temporarily disable it in order to test this.
Asumasu
I'm sorry but I do not see "Camera Rules" in Settings.
Asumasu
Yes. Both the nonrecording camera and the other 2 are able to make manual recordings.
That's because the rules are inside the mode(s).
  • 5 Replies
  • 1266 Views
