Hey,
I'm buying some new cameras Pro 4.
Today I have 3 Arlo Pro with solar panels WMA4600.
Can I use the solar panels with Pro 4 by changing the kabels?
@jguerdat wrote:
I suppose they could work
Arlo doesn't show them as compatible, so I suspect they won't work well even if you do connect them with the a suitable cable.
I suppose they could work but changing the cables would be the issue since there's no method nor cables to do this with. Patching cables could work but there goes the weatherproofing...
Arlo Pro 4
labels
Samsung SmartThings
