Arlo Pro 4 - options for changing sound notifications
I have read there are options for changing sound notifications on Android devices which is a standard feature.
Unfortunately, I have not found any on changing notifications on Apple iPhones and the ones I found go back years with no progress.
I need the ability to make alert notifications more pronounced so they can alert me at night. Plus, it would be helpful if I could distinguish between my cameras and doorbell camera. Is there anything new about iPhone notifications?
I wish in the app also you could customize sounds for each cam on Iphone like Ring. It had several sound options to set up per cam. In Android it is a phone option not the app. I thought by now you could do it in the app but people have been requesting it for years. It was really helped when I had Ring several years ago.
Arlo Pro 4
labels
Samsung SmartThings
