Hi,
I got the Arlo Pro 4 XL from Costco. My couple of friends have Arlo (older versions) and they mentioned that it records everything for 7 days.
Now for Arlo Pro 4 XL, it says 3 month trial active (which is going to end in a month) but it does not tell what is the trial about and what it will end at the end of the trial?
Will I still be getting recording of 7 days or it will change? I am not interested in any of the subscription plan.
I just want to know my options.
Thanks,
JR
All the newer cameras (starting with the Ultra in 2018) need a subscription for cloud recording. That includes the Pro 3 and Pro 4 cameras. So you will lose all cloud storage when the trial ends.
More details are here: https://kb.arlo.com/000062312/What-options-will-I-have-when-the-Arlo-trial-ends
Thank you Stephen B for clearing my doubt.
Now, in order for me store the recording, should I just attach USB drive (around 256GB) to the base and everything should work as if I am on subscription. Any else to be done in my account settings?
I am not sure as website does not provide anything in detail or anything came when I bought the product.
Any other inputs from your side would be appreciated.
Thanks,
JR
Not really the same. Direct Access to Local Storage requires a smarthub (VMB4540 or VMB5000) and is described here: https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
It has a number of limitations compared with cloud storage
- Local Storage can only be access from the app - not from my.arlo.com
- Local Storage can only be accessed from the primary account - not friend accounts
- You can not make manual recordings
- Thumbnails are not available, so you need to download and play the video before you have any idea on why it was stored.
- Remote access can be hard to set up (either needing port forwarding, or a VPN).
Also there are other subscription features that you will lose - notably cloud activity zones and smart notifications.
My Arlo Pro 4 camera often interrupts video recording! ! !
Arlo Pro 4
labels
Samsung SmartThings
