Hello,
I got the Arlo Pro 4 XL from Costco. Initially, battery was not charging at all and then I read in the community that I need to hear click when putting the battery.
I did that and now battery icon is showing it is charging, however percentage is stuck at 56% and not increased at all.
What needs to be done? Am I missing something. I closed the App and started again but result is same.
Thanks,
JR
It is now resolved. While charging, it was not in "on" mode. Once I changed the mode to "On" and moved the camera, it updated the battery percentage.
I have this as well. If you log into live view the percentage goes up and when it reaches 100% the percentage magically jumps to 100% in the app when the blue light comes on. Its just another bug with the Pro 4 I'm afraid since the last firmware update. It is charging and will show 100% its just not being shown in the app. Hopefully this bug will get fixed in a update of some kind or another sooner rather than later, along with the Pro 4's not reconnecting to Arlo servers and needing a battery power cycle if the internet goes down too (not just Wi-Fi as that reconnects but loss of internet with your ISP renders the cameras offline until power cycled which isn't great for a security camera)
Arlo Pro 4
labels
Samsung SmartThings
