Arlo Pro 4 VMC4050P cannot read the QR code
  • 1 Reply
  • 1851 Views
WebSpyder
I cannot get my Pro 4 camera to read the QR code (tried all the tricks including 3 different devices to display the code) and the camera doesn't seem to sync with my base station.  My Arlo Essential Spotlight camera read the QR code without problem. Do I need a newer base station?  If so, will I lose connectivity with my legacy cameras?
Check out this FAQ:
https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
If you want them to connect to a base or hub, yes, you will need to upgrade the base. You could connect them directly to your WiFi, if that's an option.
  • 1 Reply
  • 1852 Views
