Arlo Pro 4-Muting audio alerts
  • 1 Reply
  • 498 Views
RaginCajun5583
Somehow my audio is sending an alert for every noise it hears outside. How do I turn off or mute this? Thanks
First check the rule(s) for the camera(s) in the mode you are using.  If audio detection is enabled, then disable it.
  • 1 Reply
  • 499 Views
