Motion sensitivity at 100
When only motion is detected
Record video
Set video record time for 75 seconds
The actual setting of the camera are “best video quality”
Motion sensitivity to 100
Activity zone to 100% of the camera view !
I’ve tried “record until activity stops” and walked in circles around the camera and NOTHING more then a 2 second video !
Please help me! I have no clue how to fix this camera, and this being my second one I’m not sure If I’m just un lucky or if I’m just plain doing something wrong!
I really appreciate anyone who takes the time to read this and respond! Have a beautiful day!
Can you make a longer manual recording (while live streaming the camera)?
I attempted the manual recording and it let me record for 30 seconds but none of that footage showed up in the library. I’ve also noticed when the camera records properly about half way through the video the sound goes away. So now I’m not sure if it’s the actual cameras or possibly the software…..
In the picture i included you can see the camera go from recording properly to only going back to a few seconds. At no point were any settings changed
I'm thinking you should try contacting Arlo support using the options in the app. Since you have a subscription, phone support should be listed there as an option.
The manual recording should certainly be in your library. That might be worth trying again.
Also,
- are you simply using the armed mode? Or are your cameras set up to use a schedule and/or geofencing?
- do you have activity zones enabled?
@Dunny2000 wrote:
Yes i have the activity zones enabled to 100% of the camera view.
Try deleting the activity zones instead.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
Hi, have you found any solution to the problem?
I have the same problem with a new system with 5 Arlo pro 4.
I have an ongoing process with arlo support, but they have a hard time figure out the issue.
@RossseSWE
Do you have a case number I can review?
Hi, case number is #00445887
That appears to be a ghost transcript via chat, do you have the case number with further details of the conversation? I do not see any new cases present for this year.
I dont know how to find any other case number.
This is what i got:
Thank you for contacting Arlo Support. Your new case number is # 00445887 which you can use to follow the process with your request.
@RossseSWE
I don't see an active conversation in the case provided, what was detailed within this support case? What troubleshooting steps have you and the support team performed?
We have tested the following:
Reset all cameras and reconnect them.
Set all cameras to record 20 seconds of motion. But they still end after 2-8 seconds.
We have tried to create a new mode to ensure that the error is not there.
We have tried to start a live view and then click on record for 20 seconds. The recorded movie will only be 2-8 seconds anyway.
Now they have sent the case to someone who will check if there is something wrong with my account, but have not heard anything in a week now.
Arlo Pro 4
labels
Samsung SmartThings
