Arlo Pro 4 Flashing
Our Arlo Pro 4 has been flashing all day. Does anyone know what would cause this? I thought it was out spotlight but I checked and it was not. I added a video to see the flashing..
https://my.arlo.com/#/viewShared/F37897B0F4BCE9F9_202312
Any help would be appreciated 🙂
It almost looks like there's low light in the video so the spotlight may be turned on but then the camera thinks it's ok so turns it off. It is a rather quick on/off so that may not be the issue. Depending on how it's connected, reboot the camera if on WiFi or reboot the hub if you use that. You may also want to reinsert the camera battery to force the camera back to a known condition. If it still does the same thing, remove the camera from your account and set it back up again. If that also fails, use the app to go to Settings, Support, choose your camera model and scroll down to Contacts to talk to official support.
Arlo Pro 4
labels
Samsung SmartThings
