Arlo Pro 4 Camera problem
  • 1961 Views
mindeasyy
Hello Arlo Community,
I have installed Arlo Pro 4 Camera on the balcony of my cosmetic surgery business. I'm fully satisfied with the camera's picture quality, but recently, as we have started steaming baths when there is humidity, the vision of the camera is very blurry. Any solution regarding this must be shared as on winter days; it's normal to be foggy in a place so that it will make an issue with my security panels.
Thank you!
Arlo Pro 4
BrookeN
BrookeN
Here is some things you can do in the humidity
https://kb.arlo.com/1212134/How-to-reduce-condensation-on-the-Arlo-camera-lens
WOuld a small fan blowing over the camera lens be possible? Also, a quick wipe of a cloth that has a drop or two of something like Rain-X might be worth trying. Don't put the drop directly on the lens - put them on the cloth so only a light film is applied.
mindeasyy
Thank you for paying attention to my problem. I got solutions from all the replies as I had laced my camera a little more in height and also bought a camera skin to protect the lens from UV and fog, and it makes my Hair Transplant clinic safety better.
  • 1962 Views
