Thanks for the suggestion. We fully charged the batteries and switched them, which has now confirmed that it's a camera issue-not a battery issue. At this point, I'm not sure what else to try.
If the camera is still under warranty, you could do an RMA.
You might try putting in a fresh battery and doing a factory reset. Remove the camera from the account, and then hold the sync button down until the camera flashes amber. Then add it back to the account, and see if the battery drain still happens.
I took the battery out and put it back in, charged it, turned off activity zones, changed the settings to "best battery life" and it seems to be working okay now! I will try resetting/syncing the camera if it happens again. Thanks again for your help!
Arlo Pro 4
labels
Samsung SmartThings
