Arlo Pro 4 Battery (does not match older models purchased.)
  • 1 Reply
  • 1346 Views
Retired_Member
Not applicable
Purchased an Arlo Pro 4 camera, and wanted to be able to simply remove the battery and use the older charger of the prior Arlo models I had purchased.
However the battery is NOT the same, and therefore a separate charger is required.
These should match so that older battery units and chargers are interchangeable. Seems wasteful not to have a matching unit and be able to charge the newer unit with the older charge box. (too much profit, not enough environmental impact review of products before placing on market!)
dcfox1
The correct charger comes with the Pro4. No need for the old one. Newer batteries for Pro3 and newer last longer then the old ones.
dcfox1
  • 1 Reply
  • 1347 Views
