Arlo 4 live streaming video blury
I bought the 4 pack of the Arlo 4 Pro but one of the cameras has been blurry when streaming live but when it records a movement it's clear so how do I fix the live stream so it's clear like the other 3 cameras. I have also put in different spots of the house too see if it's the area but the other cameras are fine so is the camera faulty ? Cheers
Does it stay blurry no matter how long you livestream?
If so, I'd try doing a factory reset on that camera and see if it helps.
If it doesn't, then your best option is probably to exchange it with the seller.
Arlo Pro 4
labels
Samsung SmartThings
