Anti-Theft Mounts for Arlo Pro 4
Recently purchased set of 3 Arlo Pro 4 cameras with anti-theft mounts. The Arlo mounts won’t let cameras be mounted at 90 degrees. I see there are mounts available that allow mounting camera at 90 degrees. My question: how do you get Arlo mount separated from the camera. I don’t want to break anything.
5 REPLIES 5
JIMMYG2,
It sounds like you're referring to the Arlo Total Security Mount. You can find more details about installing/removing the mount here: https://kb.arlo.com/000062332/How-do-I-use-my-Arlo-Total-Security-Mount
Can you remove the entire anti-theft mount to install a different type of mount?
Yes, if you buy a replacement housing.
- https://www.arlo.com/en-us/accessories/VMA5202H-10000S.html
- https://www.arlo.com/en-us/accessories/VMA5200H-10000S.html
- https://www.arlo.com/en-us/accessories/VMA5201H-10000S.html
Are these available in Canada? Your site doesn't ship to Canada and they don't appear to be available anywhere in Canada.
Thank you Stephen!
Arlo Pro 4
labels
Samsung SmartThings
