Adjustable Indoor/Outdoor Short Mount screw size
I have this adjustable short mount that came with my original Arlo Pro 4: https://www.arlo.com/en-us/accessories/VMA1001-11100S.html but can't seem to find 3 screws. I think I lost them.
Can someone tell me the screw size I should look for at a hardware store?
Message 1 of 2
96
Maybe bring the mount with you, so you can check at the store.
Message 2 of 2
78
Arlo Pro 4
labels
Samsung SmartThings
