ARLO PRO 2 HUB Arlo Pro 2 VMS4230P-100NAR
- Email to a Friend
I have two Arlo Pro 2 Cameras connected to Hub so question is Arlo Pro 4 can be added to same Hub? or I have to get a Arlo Pro 3 Hub?
Model: VMB4000 | Arlo Pro/Pro2 Base Station
- Email to a Friend
Did you check the compatibility FAQ in the support section here? The 4000 is compatible:
https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
- Email to a Friend
- Compatible with: Arlo Ultra, Ultra 2, Essential wire-free, Pro 3, Pro 3 Floodlight Camera, Pro 2, Pro, Wire-Free, Video Doorbell, and Audio Doorbell.
Arlo Pro 4 is missing
- Email to a Friend
That link is not updated yet. In the Pro4 manual there are instructions for connecting to a base/hub and the 4000 is listed.
Arlo Pro 4
