adding pro 3 and new VMB4540 to our Pro 2 and reg arlo. When we change to the new hub do we need to take the other cameras down (they are up high) to sync them to the new hub?
@Nanlee wrote:adding pro 3 and new VMB4540 to our Pro 2 and reg arlo. When we change to the new hub do we need to take the other cameras down (they are up high) to sync them to the new hub?
Yes but you can keep the Pro2's and Arlo on the current Base if you have a second Ethernet connection if you want or until you can take them down.
