pro 3 light no longer turns on when motion detected
pro 3 light no longer turns on when motion detected, subscription ended. I tried making a custom rule but the camera doesn't show up in list of armed devices.
That's because you don't have a subscription. The end of the trial sub means you either need to purchase a sub or use local recordings on your hub.
