iPhone XS Max On IOS 13.6 and Pro 3
Since my iPhone was updated to iOS 13.6, the Arlo app will not display live images, provide any notifications, nor record any video to CVR.
I've deleted the app and reinstalled it with no change.
I can playback any video clips previously captured in the library, both from the Cloud and from the SmartHub.
Without notifications, I can't check using my laptop since the security notification nevers gets to my phone.
having the same problem,. i reset the base and the app. no good
There was a temporary issue that impacted some users causing the symptoms described here, take a look at the status website for details: status.arlo.com
This issue should now be resolved.
