Hello everyone,
I am contacting you regarding a new issue that started affecting my Arlo iPhone application only. Whenever I open the app and try to log in, I receive an “Unknown error” message. The issue persists even after trying multiple troubleshooting steps from scratch.
What I already tried:
- Reinstalling the Arlo app completely
- Removing all app data
- Restarting the iPhone
- Resetting/changing my password
- Logging in again with the updated credentials
Unfortunately, the result is always the same: “Unknown error”.
Important details:
- The issue appears only on the iPhone application
- Internet connection is stable
- The problem started recently (~2 weeks ago)
- I also recorded a screen video demonstrating the entire issue step-by-step:
"drive.google.com/file/d/1BpOIhNcfABGj9c7PXDSVsLaPMrmGQK-x"
Thank you in advance for your support.
The team is investigating the symptom. In the meantime, there's a workaround that should help you log in successfully.
Can you try the following?
Create a temporary Arlo account
- Open the Arlo Secure app and tap Sign Up
- Use a different email address to create a new account
- Complete the setup and verify your email when prompted
Trust your device
- Once logged into the temporary account, follow the on-screen prompts to trust your device
- Confirm that you can fully access the app on this temporary account
Switch back to your original account
- Log out of the temporary account (go to Settings > Log Out)
- Log back in using your original Arlo account credentials
- You should now be able to log in successfully
Trust your device
