  • 4 Replies
  • 2877 Views
JPA57
I cannot log into my account.  Whether on my Iphone, Ipad, or computer, it says each is not a trusted device and will send a push notification, but none is ever received.  I tried creating a new account, but that was not allowed as my name already exists.  What can I do?
@JPA57 wrote:
Email is not an option on the login screen and I can’t login to change settings
If you are using a PC (my.arlo.com), you'll see "Try Another Verification Method" at the bottom of the screen (after you enter your credentials):
Click on it, and you should see email as an option.
Have you tried email notification?
JPA57
JPA57
This worked!  Thanks for the tip.
  • 4 Replies
  • 2878 Views
