I cannot log into my account. Whether on my Iphone, Ipad, or computer, it says each is not a trusted device and will send a push notification, but none is ever received. I tried creating a new account, but that was not allowed as my name already exists. What can I do?
@JPA57 wrote:
Email is not an option on the login screen and I can’t login to change settings
If you are using a PC (my.arlo.com), you'll see "Try Another Verification Method" at the bottom of the screen (after you enter your credentials):
Click on it, and you should see email as an option.
Have you tried email notification?
This worked! Thanks for the tip.
